Joe Fusco said:Wayne,
No trouble at all. The sheen issue is a hard one to discuss because it might be subjective. How a particular sheen appears to someone verses how it appears to someone else. I do a fair amount of kitchen cabinets and I like to use a stain finish myself. Once again I hate to say this, but it's something you are going to have to experiment with to see what you like.
One thing I do is I always apply 2 coats of gloss and then a coat of the sheen I want to have. Since a gloss coating has no flattening agents in it, it makes for a more durable finish.
Mirko said:Hi Joe,
One of my suppliers caries ML. Campbell I have not tried it yet. I use Valspar Inviro plus, I like it, but I find when I use it a top very dark stains, there seems to be a faint purple haze. I usually use Valspar with their water based stains, but it seems I get better results when I used oil based stains, like Becker Acroma.
How do the products you mentioned react in the conditions I described? simply put, does it look good on dark stains?
Mirko
wnagle said:Joe,
I am new to spraying and just bought an Earlex 5000 HVLP. I am told the unit works pretty nicely even though only 2 stage nad inexpensive. It comes witgh a 2mm tip I believe. It was sugested to me to maybe go a little smaller on the tip for waterborne finishes. what I was wondering since the agualente is a little thicker, do you think the 2mm tip would work ok with it? Any other tips appreciated as well.
