I have a garage renovation I'm in the middle of, and I'm trying to figure out an exterior wall detail. It will be framed with 2x4's, with pressure treated plywood, and a 36" door in the middle of the span, it's maybe 11' at the most wide. The client wants a cedar feature wall to clad this exterior wall, and then wrap the rest of his backyard. The feature wall is no problem, I am just trying to figure out how to go about waterproofing the PT ply, so that I can then put some cedar strapping on the studs, and then put the 1x2" cedar strips horizontally. Ideally behind the cedar strips will be either painted black, or have a black material to really have the cedar pop. Would roofing felt over the PT plywood be adequate? The roof overhangs the wall by approximately 6".
In short, this is the order:
Studs, PT plywood, some kind of waterproofing, strapping on studs, 1x2 cedar detail.
