Cheese
Hey Festita...like Matt said the ThermoWorks Billows is really the bomb.
I enjoy cooking a beef brisket but because it's usually a 10-12 hour project, I only cook one every 4-5 years. And the beauty of that is that everything you learned while cooking the brisket has now been conveniently forgotten. [smile]
And then there's the issue of trying to maintain a constant grill temperature. It seems like I'm constantly opening & closing vents and by using the thermometer in the cover of the Weber, the response time is fairly slow. All of these issues mean I have to babysit this thing for pretty much the entire cooking session. I think my failure to maintain a constant/consistant temperature is the reason the brisket takes so long. I'd like to get the time to be under 8 hours.
The ThermoWorks Billows modulates the air input volume into the Weber kettle thus controlling the cooking temperature of the Weber grill. It's controlled by the "Signals", "Smoke X2" or "Smoke X4" temperature devices to vary the air input into the kettle to achieve a uniform kettle temperature. You set the kettle temperature you want to maintain and it will admit more air or less air to maintain that temperature.
So for the brisket, you set the grilling temperature by installing an air probe inside the grill, then set the meat pull temperature by installing a meat probe in the food and as a bonus round, if the grill temperature goes below the desired temp, you'll get a warning on your phone to add additional charcoal briquets. Pretty slick.
https://www.thermoworks.com/shop/products/Cooking-Alarms
