Lazy said:I want this to be portable so dealing with contactors and one of those doorbell size transformers to operate it may be more trouble than it's worth.
Bohdan said:For use with the rotex you need to fit a bag and HEPA filter as the self clean filter allows the small particles thru and without a bag you will clog your HEPA filter.
Lazy said:...
Bohdan, I want to thank you for your contactor idea. I did wire up a contactor. I put it in the smallest box possible with three short pigtails sticking out. One for the coil power, another for input power from a separate circuit, and one for output to my shop vac or whatever I want to run simultaneously. I tapped into my table saw power on the motor side of the switch housing and put a small pigtail on that. Each pigtail has a male or female 3-prong standard connection for convenience. We used this setup on site yesterday and today. It worked very well. So thanks again for your input. I appreciate it very much.
Lazy said:No it doesn't come with one as it is designed for use with plaster, which is a coarse but 'sticky' dust, but if you are going to use it with wood then I suggest that it would be really worth the added cost to get one and only use it with a bag.
