Pnw painter
- Oct 12, 2014
To the OP, this is probably some of the best advice so far. Good luck with your project!Henrik R / Pingvinlakrits said:EDITED WHOLE POST - SHOULD NOT WRITE "STRAIGHT OUT OF BED":
I have done window restorations for many years - and mostly in that material.
I would take a more simplistic approach as a few others have mentioned too.
Based on the shape and condition I would go sanding block, 180/240 (max) grit paper (depending on type of paint/finish) and make a few custom blocks for the smaller trim pieces. Seems like they mostly only need matting down. A sharp, smallish triangle scraper for digging out dirt in the corners and a small straight scraper for the running lenghts. A triangle scraper for the running lengths tends to sometimes dig in on the sides - not pretty.
For sanding the RTS400 or DTS400 would be my choice. Nothing else.
By the looks of it I am not even sure I would have used a sander. [eek]
On windows in worse shape I use scrapers, sanding block, RTS400, EHL65 planer and RAS115.
Occasionally a speed heater.
That's all I need unless I need to rebuild old windows. I have been contemplating a DTS400 or similar and that is why I eventually bought a RO90 which I did regret in the end, for some of the reasons mentioned earlier in the thread.
Be careful with the scraper - don't put scars in the wood - use it sparingly. By the looks of it it won't see much use.
Save those $$$, don't buy gear you don't really need.
