ben_r_
- Oct 13, 2015
I like it! Thanks RobBob for taking the time to call in and get that email sent. When I get my A3-31 I guess Im going to be running a new 30A circuit for it.RobBob said:Rod Sheridan states in the "Electrical requirements for Hammer a3-31" thread mentioned above that Felder warns that you should not use a 30 amp receptacle for the A3 31. Well, Delaware technical support told me yesterday and again 6 months ago to use a 30 amp circuit.Mismarked said:Rod Sheridan has a lot of posts about the electrical requirements for, and other aspects of, his Hammer A3-31 and is very knowledgeable about the machine, and I reviewed his posts when deciding to make the purchase.
If you Google "Electrical requirements for Hammer a3-31," that thread it the first thing that comes up. It was started in 2010 but continued in Feb. 2017. As of 2010, he had been running on a 15A circuit for 2 years with no problems and said he could have used 20A but not 30A because the equipment manufacturer specified the max for its equipment. He's in Canada and follows Canada code requirements. I will try to get his attention and see if he has any interest in weighing in here.
I stated this in the original thread, but now that we have a dedicated thread, I will reiterate that I am running on a 30A circuit, but had a 20A subpanel made that is attached with magnets to the back of the A3. It was quick and easy for the electrician to do, and it has worked without a hitch. I got the idea from a Youtube video posted by Thomas Gadwa. He has several showing how he tricked out his Hammer. "Power service connection for Hammer A3 31"
Hope this helps.
Others have said that the breaker protects the house wiring, not the machine.
So...figuring that we really need a definitive answer on this I called Felder/Hammer a third time. I spoke to Phillip in the Delaware tech support area (866-792-5288). Again he verified that a 30 amp circuit is preferable, but that a 20 amp may work.
I asked Phillip to send me an email stating what he told me over the phone to avoid any warranty issues should the need arise. He agreed to send it.
Here is what Phillip from Felder/Hammer tech support wrote:
"Thank you for contacting us regarding your Hammer A3-31 with a 3kW power system. As we discussed on the phone the specifications for this machine call for 230v single phase power plus or minus 10%, and the machine will be the most efficient and have the greatest service life operating closer to the 230v spec than at the outer edges of this range. Voltage lower than 230v, the starting of the machine, and eventual deterioration in efficiency as the machine ages will all cause some increase in current consumption compared to a new machine running at 230v. I am not a licensed electrician and can not make determinations for what should be installed in your shop - only a qualifed, licensed electrician in your area can do that. The machine's specifications recommends a 20 Amp circuit breaker as that will provide just enough for the machine to start and run, however to have some extra room on the circuit for other devices, to future proof for eventually upgrading to a larger machine, or just to avoid operating so closely to the 20A cutoff if you have voltage within the 10% range below 230v, it is acceptable from our perspective to install and use a 30 Amp circuit instead as long as your local codes and licensed electrician allow.
Please remember that the design of this single-phase, capacitor-start electrical system requires that you press and hold the start button until the motor is up to speed, then release. The stop button may be quickly pressed instead of held. This procedure will ensure the longest possibly life for your capacitors. Failing to hold the start button until the motor is up to speed will cause premature failure of these capacitors."
