dave_in_gva
- Dec 18, 2014
Hello FOG people,
Shortly after Felder started making the Hammer line I purchased a Hammer combination machine and their extraction system. That means I have a stationary 3HP vacuum unit giving me plenty of suction in my workshop, pulling through 120mm anti-static hose into 200 liter bags.
So far the only Festool tool I have is the Domino 500, which I'm quite smitten by. I mostly use this outside of the workshop, and have rigged it up to use a small dedicated vacuum which works quite well.
I am planning on buying the OF 1400 and I would like to set myself up with a better extraction system for my Festool tools in the workshop - ideally a strategy that can cover both the Domino 500 and the OF 1400. I'm tight on space in the workshop and see no need for buying a Festool vacuum unit (and yes I know they are great [wink]) given that I already have the Hammer system.
I can get the following 2 Hammer components that will get me close to Festool hose land:
1. A divider box with pass through for the main 120mm hose and a second outlet that can be opened or closed with a gate and has an 80mm outside diameter.
2. A reducer quick connector that I could fit over the 80mm outlet on the above divider box that has an 80mm internal diameter at one end and a 50mm outer diameter at the other end.
So that gets me down to 50mm outer diameter with a gated control.
I could either mount these two components on the main extraction unit, or mount them somewhere along the line of the 120mm extraction hose, close to the end. If I mount them in-line, I'd leave a meter or so of 120mm hose to allow me to easily plug that last meter of hose into and out of the various Hammer machine dust extraction outlets I have. The in-line option would put the gate control closer to where I would be using the OF 1400 or the Domino, meaning it would make opening or closing of the gate a little easier as well as reducing the overall distance of hose I would need since it would now be reasonably close to where I would be working with the Festool tools.
I see Festool part number 452897 is listed as "Extraction adapter D 50/D 36" but somewhat unhelpfully all the descriptions I find of this adapter do not tell me what the internal and external diameters are. I'm guessing from the looks of it that it is meant to have a 50mm hose that screws inside the larger end and a 36mm hose screwing inside the smaller end but to be honest I have no idea if the insides of this part are threaded, nor how it relates to Festool hoses and tools (e.g. fitting "into" or "over", screw fit, push fit etc.). I just want to place an order for the right stuff and I would rather not guess. I'm hoping the hands on experience of folks here with many more Festool tools can help me.
Can anyone tell me what my simplest and least expensive strategy would be to cover the distance between the OF 1400 dust extraction port and a fitting with a 50mm outer diameter? Distance I would want to be covered would be around 2-4 meters depending on whether I fit the divider box and reducer in-line or on my shop extraction unit.
As per the recommendations elsewhere on FOG I would want to be using at least a 36mm hose here. Indeed, it seems to me that one option I may have would be to run 50mm hose (although it may be more expensive than 36mm hose) direct to my Hammer reducer connector with the 50mm outside diameter and then terminate that hose at the tool end with the 452897 part I mention above...although with that strategy I am not sure if I need another fitting between the hose and the Hammer reducer connector.
Thanks for help/insight from all you Festool gurus who know the ins and outs of the hose possibilities [big grin],
Dave M
Dave M
