Hi all,
In the other day, I built a simple shoe lack with five horizontal boards (shelves). Each board had three dominos at each side.
When I attached them to the first side board, it had no drama. I just glued dominos to the shelves and push them to the side board one-by-one.
But, when I finished with all five shelves, glued the dominos to the other end of the shelves, and tried to put the second side board, I had a problem to put all 15 (5 boards x 3 dominos) into the side board at once. I did similar things in the past but this time I might have carelessly put few of the dominos crooked. Or maybe some of the dominos were too tight (dryfit went well, though). I was racing against the yellow glue and finally managed to put all them in but it was certainly not a pleasant experience.
So, I want to know how would you do it. By the way, I half anticipated it and oven-heated the dominos before I used them. So they were not too tight. I can think of the following options;
1) 18 dominos at once should be not a problem. I was not just careful or experienced enough. Do it again.
2) Just don't use yellow glue. PVA gives you much more time
3) 18 dominos are too many. I would use them only for the top and bottom shelves and rests would sit on dados.
4) 18 dominos are too many. I would reduce the number of dominos
5) Other suggestions?
I would love to hear from you on this matter!
thanks,
Susumu
thanks,
Susumu
