Where can I find Kem-aqua or Kem-aqua plus in south jersey?
rizzoa13
Title says it all. We've got a sherwin williams in town that supplies to the casinos and usually has many industrial coatings but they cannot get it. I'm really interested in the Kem-aqua for trim and doors and want to give it a try. I've got enough coming up that I could justify a 5 gallon of the white because I've heard thats all the Kem-aqua plus comes in. So where do you guys get it?
N.B. - id travel for it to give it a shot so anywhere from philly to central jersey would work.
Kem Aqua Plus comes in clears at various sheen. Kem Aqua White is its own product.
Gotcha so id just be asking for regular kem-Aqua  in white and if I felt it needed more durability I could spray the kem-Aqua plus over it?
These are two different lines.  There is the original Kem Aqua which was both pigmented and clear and then there's the new line which is Kem Aqua plus.  I've used both (my store only had the original at first).  I have heard the plus dries a little harder I believe, thus you cannot intermix the two systems, i.e. you can't spray Kem Aqua pigmented and then clear coat it with Kem Aqua Plus clear.  It has to be original/original or plus/plus.  There are also two different kinds of primer for the two kinds of pigmented.  Leave it up to SW to make things as complicated as possible.  Just stick with the Plus for everything and you'll be good to go.  Here are some links to
Kem Aqua
http://www.paintdocs.com/docs/webPD...ufficiently confused someone  [blink] [blink]
Links are all messed up, google search Kem Aqua and Kem Aqua Plus and you'll find the product data sheets for all the different clears, pigmented and the primers.
