Sure, but than you are shop bound. Won't work for OP's carpet scraper.jonnyrocket said:Our US electrical systems can produce the same 240V that is used in Europe.
Svar said:Sure, but than you are shop bound. Won't work for OP's carpet scraper.
Hz in EU is 50, US is 60. If someone runs a 240v/50hz motor at 240v/60hz there potentially will be issues over time. Just posted in classifieds that I'm looking to trade US spec tools for German spec tools since I'll be moving there this summer. Unfortunately I don't need or even know what a carpet scraper would be used for.RussellS said:Agree with the others. If you hooked up 240 volt outlets, and the right plug ends, then you can use European tools in the US just fine. Volts, watts, Ohms, and all the other electrical stuff is identical everywhere in the world. And you can use US tools in Europe too if you rewire your shop to 110 volt.
Archepg said:Hz in EU is 50, US is 60. If someone runs a 240v/50hz motor at 240v/60hz there potentially will be issues over time. Just posted in classifieds that I'm looking to trade US spec tools for German spec tools since I'll be moving there this summer. Unfortunately I don't need or even know what a carpet scraper would be used for.RussellS said:Agree with the others. If you hooked up 240 volt outlets, and the right plug ends, then you can use European tools in the US just fine. Volts, watts, Ohms, and all the other electrical stuff is identical everywhere in the world. And you can use US tools in Europe too if you rewire your shop to 110 volt.
