nickao
- Feb 24, 2008
Wilton mini wood lathe 99177
100.00 including shipping(about 25.00 to 30.00) - USA 48 only
The reviews seem good to great:
http://www.amazon.com/Wilton-99177-5-Ho ... ewpoints=1
Paid 126.00 plus shipping for it, never used it. Straps on the box and never opened.
http://www.toolguys.com/product/wilton- ... rking-lath
http://www.waltcotoolsinc.com/wiltonminiwoodlathe.aspx
Possibly use it to part out for a 4th axis or just use it as is.
Wilton Mini Woodworking Lathe
Whether you’re an experienced wood worker or just a beginner, the Wilton 99177 mini-lathe is the perfect tool for turning small projects such as pens, pencils, small bowls, bottle stoppers, ornaments and other spindle work. Ready to use right out of the box the 2/5 HP motor is powerful enough to remove materials fast and the variable speed control, 750 to 3200 rpm, with current feedback will maintain a constant speed under a load. Weighing in at around 50 pounds, the Wilton mini-lathe can be easily moved around the shop, home or garage.
Features:
* Wilton 99177 mini-lathe is the perfect tool for turning small projects
* 2.3 amp, 2/5-horsepower mini woodworking lathe
* 4-inch swing; 12 inches between centers; variable speed control (750 to 3,200 rpm)
* Cast iron bed and headstock for stability, durability
* Includes lathe, spur center, adjustable 6-inch tool rest, 6-inch and 2-1/2-inch
* 8" diameter turning capacity over lathe bed
* #1 Morse taper
* Drive spindle is 3/4"-16 thread
Features:
* #1 Morse taper
