I live in a 100+ year-old home with no shortage of projects. The current one involves a complete refinishing of two original double-sash windows and frames, and replacing the hardware (pulleys, counterweights, and sash cords). I've replaced sash cords and counterweights before which is easy and straightforward. However in this case I also need to replace 8 pulleys. Normally this would be a non-issue, a simple swap. But the new pulleys have larger plates with a corner radius and are not rectangular like the old ones so obviously I need to modify the mortise size and shape slightly. I'm trying to decide how best to do that.
My initial and obvious thought was to use a chisel. My chiseling skills are modest but solid. Though the thought of cutting 32 consistent corner radii by hand is daunting. But the ability to go slowly and (hopefully) reduce the chance of cutting too deep, wide, or long is definitely a positive. The alternative is to use a trim router which would just fit. I like that the depth of cut would precisely match the original and it would make cutting the corner radius for the plate cleaner and quicker. Of course without a template it would be very easy cut it too wide or long. Though I suppose a little wood filler would take care of any (small) mistakes. Still, I would prefer to make precise cuts and avoid any patching after-the-fact if possible.
If anyone has experience with this sort of thing or knows of a different/better approach I'd like to get your insights.
Thanks,
Todd
Thanks,
Todd
