MichaelW2014
- Jan 3, 2014
Does wood move at all over time if it is very well sealed with an acrylic lacquer?
MichaelW2014 said:Does wood move at all over time if it is very well sealed with an acrylic lacquer?
Improperly applied all will ruin the look and feel of wood. They all seal the wood against damage/usage to various degrees. Some say it slows the expansion/contraction but that varies between species and relative humidity or changes in relative humidity.MichaelW2014 said:wax, oil, laquer, etc, which seals the wood best without ruining the feel and look of the wood?
Wax is a good coating depending on usage, but doesn't prevent shrinkage/expansion.MichaelW2014 said:so if you seal it with 2 coats of wax is that at all good enough and will lead to minimal shrinkage/expansion? or is wax the worst in this regard?
I would suggest Understanding-Wood by Bruce HoadleyMichaelW2014 said:is there a set of guidelines for wood type and finish type in relation to wood movement? a guidebook perhaps?[/b]
Bert Vanderveen said:The only way to avoid woodmovement is to change the properties of wood itself. There are techniques to do this (eg high pressure boiling), but these are not in the realm of simple woodworkers like us.
Best practice is to study wood and learn from the mistakes and successes of others.
OT: keeping your brench dry will go a long way towards keeping it in good shape. Using a coating that ‘breathes' will prevent cracking of seams and ingress of moisture. Products like hard oil or epoxy require constant care and updating.
teocaf said:Lee Valley also sells a nifty wheel type calculator which is what I use:
http://www.leevalley.com/US/wood/page.aspx?p=46281&cat=1,46096,46109
In context, Flexner is against Wax as the only finish unless it is a decorative objects that won't be handled much. Wax does not offer any protection against water and is difficult to repair if a watermarked. He is however Ok with wax applied over other finishes.teocaf said:When it comes to wood movement in relation to finishes, I tend to refer to Bob Flexner's excellent reference: Understanding Wood Finishing book. Incidentally, when he discusses how to choose a finish, on page 190, he states as his number 1 point: "Eliminate wax as a choice".
You can get a copy of Understanding Wood Finishes PDF which is the first version (I think) and does not contain the same info as the updated version [member=2205]teocaf[/member] refers to, but it's still a good read and contains different information than the eponymous "Flexner on Finishing" book.teocaf said:Get the book or see if it's being published as an ebook and I think that's a very good start on this very broad topic.
