Wooden Storms - 30+
I am thinking about purchasing the Domino for a summer time project - 30+ wooden storms for my old colonial.
Anyone reproduced wooden storms that would like to share some pictures?  If not, can anyone point me to video/pics of joining two pieces of wood as in a wooden storm?
Thanks,
Chuck
    I am gradually working on storms for my parents billion year old house.    The ones I am doing are nothing special - big two light rectangular frames roughly three feet by five feet.  I am currently using butt joints with biscuits. Since I have at least ten to go perhap I will NEED( ::) ) a Domino,
Chuck Wilson said:
Do you think that the biscuits and but joints will hold?
Chuck
    I did the first one about two years ago. So far no problems. These windows don't get opened or closed very often. Or removed either. I don't see why they shouldn't hold up.  Time will tell.  I am sure Dominos (especially exterior ones)  would be better than biscuits and probably all the strength  ever needed.
I am interested in doing much the same for my 50+ yrs old house.  I expect use of my Domino will make for quick work on the frames.  What are others using for the glazing?  Anyone using plastic such as Lexan or acrylic?  I was thinking that 1/8 inch thick plastic might be a good choice to save weight and increase safety.  I am concerned about using glass due to the size and therefore weight of some of the units I will need, several of which are about 3ft X 6ft, and a couple are 4ft X 5 ft.
Dave R.
Dave R.
Dave,
    I used real glass. So far so good. But I like your thoughts on using acrylic or something.  Especially for the ones that go on the second story. It would be a lot less weight to work with up there. Lesss weight for the frame to have to deal  with holding together too!
My experience with using clear acrylic is that after 3-4 years of sun exposure it starts to yellow badly.  Then again, the last piece I bought a few months ago now claims to have a UV-resistant, non-yellowing coating.  Maybe they've fixed it.
The house I'm moving out of has some flat acrylic skylights that are still quite clear. We've lived in the place for 3 years, but knowing what I do of the history of the place, I'd bet they're 10 years old, so it's probably a matter of what type of acrylic you get.
Lexan won't yellow, and is shatterproof. It's reflected in the price difference between that and plex, which I think is UV stable for all but the cheapest brands (plexiglas is proprietary). I wouldn't use 1/8" for anything bigger than about 2' square, it might bow enough to pop out of the frame if there's any wind. If it was me I'd use at least 1/4" for a 3x5 or 3x6 frame. 3/8" would be enough to stop coconuts or suicidal chickadees. I'd probably use silicone to mount in the frame.
    Yes, good thoughts.  BTW will 3/8" stop a swallow carrying a coconut?  ;)
Semenza said "BTW will 3/8" stop a swallow carrying a coconut?  "
1/2" Lexan will stop a 357 magnum  & is used in airline wind shield.  However the last time bought a couple of sheets ( 1 - 4 x8, 1 - 5 x 9) of 1/2" Lexan  for a stairway I built for a customer the wholesale cost was over $1k....  1/4" Lexan was about $10 per before oil went to $100 a barrel.  At those price it had better "stop a swallow carrying a coconut?"
jim
Most of my experience with Lexan was making camera shields to stop bullet hits. 1/2" is the standard. I never bought it myself, but it's use was a good indicator of price. When I first started in the film business, we used to cut four shields at once, and peel fresh paper on a piece for every take. When I left the business last year, we'd been using the same shield for four shows, and only g*d would help you if you scratched it.
Thanks, Eli.  Where I live I've got lots of crazy squirrels, racoons, deer and various birds (some of whom do occasionally try to fly through a window or fight their refected image), but no coconuts.
Dave R.
Damn, I almost missed the perfect setup.
Were you asking about an African or European swallow? ;D
Would anyone care to share photos of the storms?  I have some pics of mine that I plan on posting ASAP.
Regards,
Chuck
Eli said:
Eli,
  I wondered how long it would take for you or  someone to catch that  :D
          Didn't mean to take it off topic, but I couldn't resist with  "bird" and "coconut" showing up in your post about the strength.
Regards,
Chuck
      I will try to remember to take some pics the next time I am at my parents house where the windows are hung.
Question:
Could/Would you use pocket screws for the windows?
Also, how about those tenons from woodcraft and a router/mortiser?  Dowelmax?
What do ya think?
Chuck
On boats you see Lexan and similar products used for fixed lights, port lights, and hatches. Exposure to UV will cause it to craze over time, requiring replacement. I would guess, depending on exposure, that it could take 15 years on storm windows.
Chuck Wilson said:
Question:
What do ya think?
Chuck
All are good options. The tricky part is getting some one else to paint for you.  ;D
