Woodpeckers BigCal
Ultimate Tools Marketing
Festool Dealer
Burnaby, BC
Precision Jaws for Accurate Measurements
Order deadline is Monday August 19, 2024 at noon. You must pre-order to get these items. Delivery is scheduled for November 2024. 
Woodpeckers BigCal Woodworking Calipers is the ultimate tool for achieving piston-fit accuracy in your woodworking projects.
  • Precision: Perfectly aligned jaws and a dual-function nut ensure accurate measurements and prevent slippage.
  • Versatility: Use BigCal as a T-square with fixed zero-lock jaws and milled tips for tiny slots or grooves.
  • Ease of Use: Engraved scales in 1/32 inch and 1 millimetre graduations, readable from either end.
  • Extended Range: Measure up to 24 inches with the larger caliper and over 12 inches with the smaller one.
  • Convenient Storage: Includes a wall-mountable Rack-It for easy access.
Woodpeckers BigCal is available in a combo set with two sizes or can be purchased individually.
Experience the precision and quality that Woodpeckers is renowned for in your woodworking projects.
Pre-Order Now
