- Sep 21, 2022
"A router on its own is a lot like a draft horse without a harness - a lot of power with no direction.
Lucky for you, Woodpeckers has the perfect solution for you!
The Woodpeckers Multi-Function Router Base harnesses the power of your router, transforming it into an accurate portable milling machine with micro-adjustment capabilities. It fits nearly all routers and enables controlled straight line or arc movements.
Whether you're machining circles or arcs, creating decorative patterns, slotting, mortising, or routing recesses, this tool unlocks your creativity and delivers unparalleled accuracy and easy set-up.
Take advantage of this special pre-order opportunity, which is only available until June 30th.
Ready to take your router to new heights? Click to place your order now!
