Woodpeckers Straddle Squares available for pre-order
Ultimate Tools Marketing
Festool Dealer
Burnaby, BC
Available for a limited time only - the Woodpeckers Straddle Squares!
With a simple, three-finger operation, these squares provide quick adjustments for perfect layout marking on three faces all at once. The spring-loaded plunger allows for a tight grip that won't slide off, and yet can be easily nudged to adjust the position. It’s as easy as Press, Place, and Mark.
We offer two sizes to cater to all your needs. The 3/4 inch model is ideal for most furniture and casework, while the larger version is designed for larger furniture and construction framing.
Built to last a lifetime, each Straddle Square is crafted from aircraft-grade aluminum and comes with a stainless steel plunger. Remember, perfect joinery begins with perfect layout, and that’s what Woodpeckers' Straddle Squares promise.
The Woodpeckers Straddle Squares are OneTIME Tools - so be sure to order yours before they're gone!
Interesting marking tool, but any reason why not making just one square to cover the full thickness range from 1/4" to 1-3/4"?
[member=57948]ChuckS[/member] Good question. I do not know, but perhaps it is due to ergonomics/ease of using the plunger, or that many users don't need anything larger than 3/4 inch.
I just assumed that it was to keep the travel to a minimum on each size.....plus they can extract a few extra dollars too  [big grin]
To avoid parallax error causing inaccurate marking because of the empty space on thinner timbers when marking all round?
