ben_r_ said:Looks like they added a new kit to the line up that includes the 18" and 32" rails instead of all 18": LINK
Cheese said:The longer tracks will not have the machined slots, but can still be attached to the tracks from the kit.
whitesys said:How would you attach the plain SuperTrack to the kit without the slots?
Cheese said:I’d really rather see the longer Super tracks laser marked and have slots milled in them to mirror the clean design of the 18” & 32” tracks. I would doubt that’d be more than a $10 upcharge per track.
HarveyWildes said:Don't the 80/20 folks have reasonable upcharges for milling connector holes in the ends of their extrusions? I'm thinking someone has figured this one out.
I can mill slots with a hand router and a plywood jig in a matter of minutes, but I cant engrave scale on the extrusion. That requires some serious equipment.whitesys said:Longer extrusions with slots would interest me.Cheese said:I’d really rather see the longer Super tracks laser marked and have slots milled in them to mirror the clean design of the 18” & 32” tracks. I would doubt that’d be more than a $10 upcharge per track.
I could live with or without the laser scales.
Cheese said:HarveyWildes said:Don't the 80/20 folks have reasonable upcharges for milling connector holes in the ends of their extrusions? I'm thinking someone has figured this one out.
Yes 80/20 does...I mentioned in another thread that I own a Woodpeckers 50" rule that is laser engraved, my question was, then why can't a 48" Super track also be laser engraved? If the laser can do 50", it should certainly be able to do 48".
Where I'm going with this is large pieces of capital equipment, be it a CNC, laser or automated plasma cutter, the only way you get your monetary payback is to place it in service and use it 24/7. A piece of capital equipment sitting idle is actually costing you money.
greg mann said:It would seem they could do a 48 inch length on that machine. The question is why Woodpeckers is not recognizing a sustainable market for this product. One could argue it might be more user friendly than the MFS and has the potential for added componentry, like for countertop joining or special radius inserts for the corners to make custom cut-outs.
"Reason" is not the term I woul use describing Festool marketing strategies.Brice Burrell said:Festool stopped selling the MFS for a reason ...
ScoFF said:I'm wondering what size area the 32"x32" track would give you for inside routability. Not sure if the width or the tracks and accounting for the bushing.
Anyone with the MFS700 know? I do a lot of cutting boards with juice catchers and want to know it's limits for cutting board sizes.
Since the 18" and 32" track "appear" to be the same width, it might be safe to say they are roughly 5" and therefore the 32" rails would allow about 27" of router cutting.Cheese said:ScoFF said:I'm wondering what size area the 32"x32" track would give you for inside routability. Not sure if the width or the tracks and accounting for the bushing.
The current ad copy for Woodpeckers reads, "The standard 18" long sides allow about 13" of router cutting".
https://www.woodpeck.com/variable-router-jig.html
Urgh, sorry, thanks for the catch. I just woke up. Fixed the post.bnaboatbuilder said:I think you mean 27" for the 32" track. You only need to take off 5" from whatever track length to know it's approximate max cutting allowance.
ben_r_ said:Since the 18" and 32" track "appear" to be the same width, it might be safe to say they are roughly 5" and therefore the 32" rails would allow about 17" of router cutting.Cheese said:ScoFF said:I'm wondering what size area the 32"x32" track would give you for inside routability. Not sure if the width or the tracks and accounting for the bushing.
They are the same 3.85" width.ben_r_ said:Since the 18" and 32" track "appear" to be the same width, it might be safe to say they are roughly 5"
Huh, then perhaps the other 1.15" comes from the guide bushing?Svar said:They are the same 3.85" width.ben_r_ said:Since the 18" and 32" track "appear" to be the same width, it might be safe to say they are roughly 5"
