- Sep 21, 2022
Introducing the new Woodpeckers Rout-N-Plane Benchtop Board Mill
From laminate trimmers to 3 HP monster routers…Rout-N-Plane works with them all! We are offering this new Woodpeckers product by pre-order until December 29th at noon.
Allows safe and controlled levelling with a router:
- Levelling an end grain board should never be done on a jointer or thickness planer. It's not only ineffective, it's potentially dangerous. Levelling them with a router sled isn't exactly a new idea, but Rout-N-Plane offers convenience and flexibility you can't get with shop-built sleds.
- You can use Woodpeckers Benchtop Board Mill with small laminate trimmers to monster 3 HP routers - whatever you have. Just install a suitable bit up to 2 inches diameter and go to work.
- Rout-N-Plane adjusts in seconds to safely guide any router across any board from 3/4 to 3 inches thick. It works on boards up to 15" wide (based on a 6" diameter base with a 1" diameter cutter). And length is only limited by how much table you have.
