P Peter 50 Member Joined Jul 31, 2017 Messages 1 Jul 31, 2017 #1 Does anyone now we're I can get worktop jig pegs from
Distinctive Interiors Member Joined Apr 17, 2012 Messages 449 Jul 31, 2017 #2 Which worktop jig is it...? The Festool alloy one or a resin/phenolic version?
Klemm Retailer Member Joined Nov 21, 2015 Messages 850 Jul 31, 2017 #3 not sure I understand "worktop jig". Do you mean something you can use to make your own 20mm hole pattern on 96mm centers? - like a ParfGuide? Hans
Distinctive Interiors Member Joined Apr 17, 2012 Messages 449 Jul 31, 2017 #4 I assumed he was in the UK coz it's a commonly used description over on this side of the pond. Here is an example of a jig...... http://www.axminster.co.uk/ujk-technology-700mm-variable-angle-worktop-jig-508615 And a spare set of pegs to fit it.... http://www.axminster.co.uk/ujk-technology-aligning-pins-for-worktop-jigs-508621
tjbnwi Member Joined May 12, 2008 Messages 7,047 Jul 31, 2017 #5 [member=59331]TSO Products[/member], Peter must be "across the pond". What we call counter tops they call work tops. A work top jig allows them to put a masons miter (we'd call it a jack miter) into the top and join them at 90º to each other. Tom
Bob D. Honorary Member Member Joined Feb 22, 2016 Messages 3,014 Jul 31, 2017 #6 Never fit one but their joints look easier than our (US) full miters on countertops. Especially when you have two closed ends (walls) and a U-shaped top that runs from wall to wall.
Distinctive Interiors Member Joined Apr 17, 2012 Messages 449 Jul 31, 2017 #7 This is an example of what the finished joint looks like when cut with a router and a worktop jig. [attachimg=1] 40mm thick Duropal particle board laminate worktop/countertop..! Attachments DSC00692_zps77988bdc.jpg 58.8 KB · Views: 1,048
