...I bet that's never been asked before on the forum [embarassed]
I'm considering both of the Domino models, and I suspect most of my use would be in 3/4" ply and MDF, as well as 1 1/2" to 2” pine, with the occasional 2x4. As such, it sounds like the DF-500 would probably be the better option. The Seneca RTS-500 has muddied the waters though, and I'm very tempted by the DF-700’s huge depth capability (even if I haven't identified what I'd use it for yet).
However, I've never used either, so I have (what are probably a few obvious/dumb) questions:
I was thinking that the DF-700 might be good (with the 12mm cutter) for making the kind of fences you get on the side of cots and children's beds - I could make 12mm thick slats with a ~1/4” round over, and mortise holes with the DF-700. Is that a realistic application for the Domino (i.e. mortise holes that would be visible)?
I see that the DF-700 only has the option of exact and +3mm for the mortise width, but the smaller model does three, and wider. What's the gist here? Is that a problem, or is it not really relevant? I know you could obviously do multiple cuts for a wider mortise but I'm just wondering what the use cases are, and if the DF-700 is "lacking" in this regard.
I'm conscious of the fact an 8mm tenon and a minimum plunge of 15mm might be a problem for a tenon-supported butt joint in 3/4" ply. The Seneca adaptor would allow a smaller bit+tenon, and I assume a plate or shim on the fence would allow a DF-700 to plunge a shallower mortise? Oh, and a plate/shim to centre a mortise on 1/2" material (I'm assuming that's required as the minimum fence height is listed as 10mm).
I can't afford both models, so, with the Seneca RTS-500, would the DF-700 be a good all-round choice? I.e. with the odd shim, and accepting the higher weight, is there anything the DF-700 can't do (vs the DF-500)? Another way of putting would probably be: are there DF-700 owners (with the RTS-500 adaptor and some DF-500 bits) that wish they'd just bought a DF-500 instead?
Thanks in advance for any advice.
