- Jan 28, 2018
Thanks!
Bugsysiegals said:How did you attach your casters to the bottom of the extrusion? We’re you able to use t-nuts?
ryanjg117 said:Gents, I recently came into possession of a table made from 80/20 extrusions that I’m breaking down or actually reconfiguring to serve as a second JumboMFT or assembly table. I’ve come across a right angle internal fastener I haven’t seen before, and none of my hex keys seem to fit it. It looks to be about a 7mm hex hole, and of course 7mm is the hex size that seems to be skipped in most sets. But, I’m not sure if a hex would even work here as the fastener seems to have some key veins, 6 point it appears. Never seen a tool like this so wondering if you know how I can remove these threaded inserts.
Here are the pictures:https://photos.app.goo.gl/UNCtk0ed2Rjqm6uv2
Michael Kellough said:[member=51886]ryanjg117[/member] please try to get more info on the source of that material. It is not made by 80/20 but some other company.
Also, very interested in the source and name of that hollow set screw. It allows the movable butt joint connection needed to make an MFS type construction without the milling usually required.
I’ve never seen a screw had like that either but try Torx.
Richard/RMW said:Agree with Michael definitely not actual 80/20 extrusion but I would love to get my hands on some of those fasteners. If anyone tracks them down please post the info here.
Thanks.
RMW
(EDIT) After re-looking at the photo seems to me the part threaded into the extrusion requires a custom key for installation. Looks like it might also be factory installed based on the dimple that appears to be peened to lock the fastener in place and prevent it from turning?
RMW
wheely said:Installation instructions for the Item Automatic fasteners can be found here, you may need to register to get the PDF.
http://www.item24us.com/media-center/installation-instructions/fasteners.html
http://www.item24us.com/fileadmin/i...K_MONT_automatik-verbindung__SEN__AIN__V1.pdf
