Zinsser Bin primer HVLP gun clean up. Any tricks?
I have been using a 2.5 Liter Ultrasonic cleaner/heated tank and using a diluted orange citrus cleaner degreaser 10-1 ratio
Cleans gun and parts perfect.
Hi Brewster201, could you give me a bit more info on your ultrasonic cleaning method? I have an ultrasonic cleaner for use with brass and gun parts. Which orange citrus cleaner do you use, and which HVLP parts do you put in the cleaner? I'm assuming you can't soak the entire gun per manufacturer recommendations (I have a Fuji).
Thanks!
Eric
QuailRider43 said:
Is it safe to assume that the seals in most HVLP guns are acetone compatible?
Havent had a problem and I spray sometimes using a mixture of stain acetone and clear and use acetone to clean my gun when I use that combo
