1
It is only a rough calculation. You can surely do a joke.
[wink]
Those '45's' are CLEARLY not 45's, so your 90's are not 90's. You can even see it in the picture.
Check the angle setting on whatever tool (table saw? Track saw? ) you used to cut the 45 degree cuts with.
Hi Rob
From where I am sitting it looks as though the top and left hand pieces are slightly wider than the others - this could be an optical illusion of course. As for the 45 deg check - only you can do this.
Perhaps you could check both aspects and let us know.
