A Aidex Member Joined Jan 16, 2014 Messages 22 Mar 4, 2014 #1 Hi Guys Can the TS75 use a 216mm blade? Ive searched lots but can't seem to find a definite answer. Thanks for your help! [big grin]
Deansocial Member Joined Mar 14, 2010 Messages 2,110 Mar 4, 2014 #2 Yes I've used mine out the chopsaw a few times
A Aidex Member Joined Jan 16, 2014 Messages 22 Mar 5, 2014 #3 Hi Thanks for that. Does it cause any problems - grinding noises etc or does it fit just fine...like a proper Festool one would...would like to try some Freud and Ultex blades. Thanks again!
R rst Member Joined Nov 10, 2013 Messages 3,305 Mar 5, 2014 #4 Amana carries German made AGE blades and they work fabulous...
C Caly Member Joined Jan 1, 2011 Messages 60 Mar 6, 2014 #5 I had to remove the riving blade. In fact don't think it as been in for the last couple of years now.
F fin Member Joined Sep 5, 2013 Messages 176 Mar 6, 2014 #6 216mm blades are negative rake normally arent they? meant for chop saw use. would that not cause a problem?
