A bump. Spent last weekend working on a bathroom. I cut and banded the faces for all the cabinets. They came out much better than I thought they would. (See picture below.) I think they are a better quality than the ones they are replacing.
A couple of new issues. Boy it took me a long time to place the faces on the boxes and screw them on (from the inside of the box). Any tricks to how you do this as I can't use any clamps easily and holding the face, the drill and the face doesn't work well. Should I make some marks on the draw, take the draw out of the box and then attach the face?
Another issue: In a few places in the house the side panels on the boxes are visible and in bad condition. They are joined by biscuits. Can you reliably take a side panel off and rejoin with biscuits? I guess another Festool product is in my future. Any advice on how to proceed?
Although the banding went well, it takes a lot of time (at least for me). I iron on the banding. Then I use a block to rub the banding down with the glue. I snip the ends with the festool edge band cutter (I know it is expensive and overkill but it really makes perfect cuts). I then use a couple of techniques. One is to use my RO 90 sander held at a 45% angle to where down the excess banding. I then carefully hand sand the band until it breaks along a smooth line. After that I use a block and a hand sand paper to remove the excess glue.
This weekend is on to painting with poly!
