leftistelf
- May 24, 2008
About to spring for the 2424 hole-y guide rail, but I got to thinking about the approach to side panels on large cabinets.
Typically, bottom and top panels fit between the side panels. The adjustable legs go under the bottom panel. The side panels are attached to the bottom/top with dominos.
However, when building a tall cabinet that will have some weight in it, I'm thinking that the side panels might be best positioned on top of the bottom panel, so the bottom panel can support and transfer the weight on the side panels.
That gets me out of the 32mm system and makes me think that the long rail might not work as designed (16 up and out on the end tops, right?).
Any thoughts? Am I needlessly worrying about weight? Would the long rail be adjustable for a bottom panel solution that is different?
Garage install, need to use legs to keep cabinet off floor (it gets wet on the area) so I can't use a 2x4 base. 18mm ply.
