492574 Small Bore Base for OF1400 problems
ear3
New York, NY
The base arrived two weeks ago, but I just pulled it out to use, and discovered that the base was cupped.  Fortunately I'm still within the return/replace window, so I will be sending it back, but I'm wondering if anyone has had issues with this or some of the other thin router bases being defective in this way?
Thanks [member=37411]Edward A Reno III[/member]
That's a ton, appears to be around .060'" or about 1/16". I guess I would expect a flatness of around .015"-.020" to be typical.
Edward A Reno III said:
... Fortunately I'm still within the return/replace window, ...
The warranty is legendary, but one would expect that the quality would not necessitate a claim.
There is not a lot of Q&A involved in checking flatness.
Better check... It may also be askew to the axis of rotation. (or the base is tilted).
I thought this might be the case, so I went to the dealer and checked their stock of small bore bases.  They were all perfectly flat.
Bert Vanderveen said:
Might be a lot flatter if it is connected… And if that is true this is a design choice.
