Brice Burrell said:
Cort, I picked up the #452897 Suction adapter (funnel shaped adapter) about a month ago for this same reason. I've found myself on the job wanting my D36 hose for routing, clean up and so, not wanting to have to keep removing the hose for the Kapex I thought this would be a better solution...
The small end of the #452897 is too small to fit correctly into the D36's tool end. Unless I'm misunderstanding something here.
Well, unlike you, I don't have the adapter, nor even a 36mm hose, but David McGibbon of Festool Tech Support, who wrote the Technical Note, seems to think they fit.
Here's the photo and accompanying text from the Tech Note:
[attachimg=#]
Since the adapter is called in the UK "Extraction adapter D 50/D 36 AA", and the Festool USA website describes it as "Non-antistatic hose reducer. For reducing from 50mm to 36mm hose", if it doesn't fit a 36mm hose, then something very odd is going on.
If you've got them sitting there, what is the outer diameter of the small end of the funnel adapter, and what is the inside diameter of the tool end of the 36mm hose?
Forrest
