Dual hose switchable blast gate for CT vac
jt073
This is an esoteric adaptation/cannibalisation of a Festool CT-VS to create a switchable inlet for two vac hoses.
In my “project workshop”, I use a CT26 for everything:
-  power tools including Kapex with a 27mm hose
-  Inca bandsaw and Inca planer with a 50mm hose; this works quite well and handles the mostly light chips from the planer (I don't have space for a big extractor as in the “main workshop”).
But I find it a pain to bend down and swap over the hoses (when I remember); so I have planned for a while to work out a blast gate arrangement that would leave both hoses connected.
I found a cheap CT-VS and I already had an old Y-piece adapter that I have never used.  The CT-VS is described as a “Sealing Slide” intended to shut off the vac inlet port when changing or shaking the bag/filter - incidentally it seems complete overkill for that purpose.  However, I figured it could be hacked about to do what I wanted, as shown above.
I have scribbled out on the parts diagram roughly what I did which might be self-explanatory for anyone sufficiently interested.  The challenge was how to join the bits of plastic - this is PP, which is difficult to join except by welding - I only had my little butane micro soldering iron that just about did the job - it ain’t pretty and it might be a bit fragile, so if the new spigots break off, I will try a heavier-duty weld.
[attachimg=2]
I inserted two strips of Delrin to help the full-length slide:
[attachimg=3]
With a bit of fettling, this works rather well.  It may be of interest to others, but really I would like Festool to make a proper one - this could be done fairly easily using the existing patterns for the CT-VS slide.
[attachimg=4]
[attachimg=5]
[OK, I still have to remember to slide the blast gate over to change hoses, but less unsnaking hoses around on the floor.]
Cheers
PS
In case you are wondering about the integrated bluetooth module, which keeps the spare outlet port free for another module, I wrote this up years ago - it has been very good.
Thanks for sharing, Scholar.  Also a reminder for me... I still have that bluetooth button on my todo list.
Thanks for posting... [big grin] ...this is exactly what I was looking for to use in the shop. I have the Kapex on a 50 mm hose and use a 36 mm hose for general cleanup. The auto start will operate the CT for the Kapex and the Bluetooth button on the hose will operate the CT for general cleanup.
Hi, nice solution, etsy has a couple of set-up also 30$ and 90$
I built a vacuum switcher 14 years ago and it still in working order
If you do a forum search …. Festool switcher ,  you can see my version
