Packard
squall_line said:tjbnwi said:The issue with the button head binding screws will be drawer box side clearance. The screws and barrels need to be flat head that recess into the slide. The drawer boxes have very little clearance to the slide.
Part of me says that binding screws are also only called for if you know that your slides will always be at the same height between the boxes. Otherwise, you're adding extra screws and still need a separate type of screw for the outside panel.
A fixed-length confirmat that doesn't interfere with a screw from the other side seems to be the most appropriate for universal application.
OK, but “Euro screws” appears not to be the best google search words. I get far more hits with: Counter-sunk Chicago screws. Many are metric sized.
I didn’t try the search, but “sex bolts” seems quite universal too. So try that too. And while metric might be standard, there are fractional sizes that match up well.
This UK company carries them in increments of 2mm in length. You will have to determine the correct size. https://www.fastenright.com/general-fixings/socket-countersunk-sex-bolts/sb03
https://www.google.com/search?q=counter-sunk chicago screws&ie=utf-8&oe=utf-8&client=firefox-b-1-m
Amazon sells an assortment described as “countersunk”, but the photos do not appear to match that description.
https://www.google.com/url?sa=t&rct...usg=AOvVaw2caUZXkT2G7LpPBhLKZMYO&opi=89978449
