leakyroof
- Mar 23, 2011
I hearby second that request... For a heavier backing, on Granat... Not asking for much, just a bit... [embarassed]Brice Burrell said:suds said:Been sanding with my RO 150 FEQ and it's been taking quite a bit of time because or my work schedule and lousy weather. Unfortunately my plug to RO failed and now I have to send it in to get it fixed. Evidently this is a common problem if the plug does not "click" in place.
Wondered if the Ras 115 would be a good substitute for this job? I've been using Granat and going through lots of it to get to bare wood so maybe the Ras is a better choice or a good substitute? I've been thinking of getting one since i have a number of wood sanding projects.
I like the Granat but it might not tough enough for this kind of heavy sanding. Id love to see Granat with a thicker more durable backing material. You could try Cristal if you're finding the Granat to be falling apart on you. You'd need to be careful because Cristal can leave a deep scratch pattern behind that can take a lot of work to remove.
The Ras would work but you'd need to get through the learning curve to sanding without doing damage on the softwood.
Maybe we'll get it with Granat2.... [wink]
