96 mm Spacing for Sys3 M 89 Organizers on Sys3-SN/4 Rails
dlu
Seattle(ish)
I'm building a case for some M 89 Organizers and I've got some of the Sys3-SN/4 rails that I'd like to use. Can I drill the mounting holes using a LR32 rail and spacing them at 96 mm? Will that leave enough room to lift the Organizers over the retaining lip on the rail? The retaining lip seems to be about 5 mm, but it is "complicated" and set back from the front, so while it looks like things might work, it would be nice to hear about real life experience.
Has anyone tried spacing the rails 96 mm apart?
Well Systainer.store says to leave 1/4" - 1/2" above the mounted Systainer, so that would fit.
  • Like
Reactions: dlu
Answering my own question, and confirming @Coen's answer: 96 mm spacing works nicely. It looks like there is little or nothing to spare, but there is no interference with the Organizers above or below.
