Let's take this great review to another level.
We are building a nicely detailed deck with a rap around bench and flower storage totaling about 60lf. I installed standard 10” x 24t bored to 30mm blade that has made over 150 cuts on wet sloppy pt . The saw has performed just as smooth as is if it was cutting crown with a brand new 80t. Switch to the stock 60t blade and cut a bunch of composite trim, pine and poplar for a few windows and door that was replaced on this deck job. Keep in mind that we still use a Worm drive because it’s silly to throw a 2x10x16 on a miter stand. We use the Kapex for blocking as well finish work.
I have a few other blades ranging from 24 - 40t that have been dropped off for boring and all will be used for the IPE, PT and the reclaimed 100/yr 3x10-12” old joist.
Kapex is hooked to the Midi less then 25ft from outlet with a 12/2 cord and 36mm hose shortened set at max speed of 6 for almost 3/days. Anything longer gets a 50ft 10g cord.
The purpose of buying this saw and vac combo was to be able to have a best all around package.
The objective was:
- Be portable as possible. Light weight.
- As compact as possible. Smallest footprint.
- As much capacity as possible. More then capable
- As accurate as possible all the time. Perfect.
- Easy to use. Easiest on the market
- Dust collection. 90% +
- Durability. Must handle Day in / Day out. Constantly on the go. Full range of materials.
- Light weight. One Handed up narrow stairs, halls, doorways or up the ladder and on to roof top.
- Only want One saw to do it all. It does.
Proven to cut anything you can fit on it. Just make sure to change blade for the application and keep extra on the truck.
I had an idea of time savings with minimal clean up but it really didn’t occur to me until I started using the package. Then it hit me like a 2x across the head. I still have a hard time understanding the lack of clean up. I wanted a Miter saw to handle everything from light framing to finish. And I mean everything in between. You’ll get it here and a Raise..
Festool has a customer for life! It's not just the tools but the service that follows.
BTW when are you going to take the classes on the road? Shane I think you we are to busy for trip to headquarters.
Thanks again,
Yannis N. Tsakiris
www.citydecksinc.com
www.citypropertiesinc.net
