ROb McGilp
 - Apr 5, 2007
Hi all,
So having prepared my timber for production on a planer and using the TS75 to square and cut to width, it was time to make the box.
You only need one tool.. the Domino.
Pic 1 shows the basic frame of one panel.
Pic 2 shows the panel dominoed together
Pic 3 shows the Domino ready to produce the 5mm trenches for the panels and base. You can see the 23mm plastic collar in place on the piston.
Pic 4 shows one assembled frame with the trenches routed with the Domino
Pic 5 shows the assembled unit. Note that this is a dry assembly. I might get round to gluing it if it starts to move.
The timbers I used are Peruvian Walnut and Alpine Ash.
The whole process took about 2-21/2 hours.(including prep time for the timber.)
Regards,
Rob
Regards,
Rob
