Ash and Red Oak Display Cabinet
Rutabagared
Another ash and red oak display cabinet (Sorry for the pic quality.  It’s the only one I have of it.)  Domino used for all joinery.  Book matched carcass pieces, door components and back panels.  The base is red oak with rails made using rip and flip technique with 8/4 stock.  Base is dyed with 2 coats of Transtint golden brown.  Piece is finished with 4 coats of Target Finish EM6000 Production Lacquer (I use this when a warmer, “varnish” tone is desired as the EM7000 results in a water clear finish).  Waiting on the glass shelves to arrive.
Does anyone have a recommendation for a light?  She wants something adjustable and Bluetooth compatible?  Thanks.
I used LED strips available from Lee Valley for a tool cabinet -
https://www.leevalley.com/en-us/shop/hardware/lighting/led-tape-lighting/110940-all-in-one-led-tape-lighting-kit?item=00U4619
[member=44099]Cheese[/member] has lots of experience with LED's and might offer some additional ideas...
Cabinet looks really nice.  The wood choices and attention to grain are excellent!
Bluetooth compatibility probably adds more complexity.  I like the small remote option in this kit as you can use velcro and attach to the back of the cabinet and make access easy.
Thanks for sharing -
Thanks for the kind words.  Aligning the door rail grain can be a real pain depending on just exactly how square your doors and cabinet are.  This one came together well, better than any I've made previously.
That option from Lee Valley looks interesting.  I'll definitely dive deeper into that.  Thanks for the link.
[attachimg=2]
That looks really nice. I have a question about the divider strip in the doors. I see that they are not there in the pic that appears to not have glass yet. Are they just applied to the surface?
Michael Kellough said:
“ Cabinet looks really nice.  The wood choices and attention to grain are excellent!”
What Neil said.
Thanks.
The dividers are not fixed to the door or glass.  Instead, they are “floating”, held in place by a combination of the glass panels (2 per door) and glass retaining strips.  There’s a 1/8” groove cut along the full length of each long side of the divider to capture the glass panels.  There’s a notch crosscut into the front of each end of the divider (top and bottom), enabling it to “half lap” into the door rabbets housing the glass. The two glass panels capture each divider (holding it in place), and the retaining strips then hold the glass in place.
Regarding the retaining strip/divider configuration, I’ve made them two ways:  the first is to make the horizontal retaining strips full length, cutting a notch in the retaining strip that straddles the divider (top and bottom).  The second (less secure way) is to simply butt the retaining strips tightly against the divider – the glass holds the divider, and the retaining strips hold the glass in place only.  These doors are made the latter way, necessitated by the fact that I simply didn’t have the door thickness to make wide retaining strips (This is the first time I’ve done it this way, but it seems just as secure and is much easier).
It can be difficult to visualize based on a description (especially mine).  I’m starting another one, so I’ll get photos of the divider.
I also made a clock and China cabinet for my dining room about 20 years ago where I simply applied the dividers to a single sheet of glass with silicone, saving a lot of fuss but visible from the back side of the door.  They are still in place today (below).  I often thought about criss-crossing the dividers on display cases similar to this (just two per door though, biased toward the side and bottom). If I do, I’ll fix them with silicone.
Here is a follow-up of detail on the glass divider strip.
[attachimg=2]
[attachimg=3]
Notch in glass retaining strip that straddles the divider.
[attachimg=4]
[attachimg=5]
That's a cool detail and lots of work to include it. As I said before, very nice work. It looks great.
Do you do this kind of thing for clients? or just for your own home?
Thanks for the kind words.  It means a lot after seeing your work.  I do it mostly for myself and family.
