lwoirhaye
DynaGlide said:So continuing the discussion I have a material question. My desk is from IKEA and the veneer has worn through showing what I believe is particle board, no surprises there. The edge banded front has a 45 degree bevel both top and bottom. I like the look of this and am not sure what was done to achieve it.
[/img]
PVC edgebanding is made in thicknesses up to 3mm. It's not cheap though so I'd be a little surprised to see it on a IKEA product. I think they're using ..45mm on their premium cabinet boxes and something like 1.5mm on their slab cabinet doors. You might be looking at a situation where the whole desk top is made and then coated - something like thermofoil perhaps. Whatever it is, it has an embossed grain on both the top and edge. If you can find a seam on the bottom that might indicate a material like thermofoil.
In terms of getting a thicker banding on a piece of ply in a small shop so you can put a chamfer or roundover on it, lots of approaches work. A pinner with glue may be the simplest... though perhaps the joints won't be as tight as you might get with clamps.
