Adirondack Chairs and Deck Cooler
Mike Goetzke
Built some chairs for the front porch/deck that I recently built at my wife's request. For this project a track saw really excelled. I used the track saw to cut all the lumber to size. Plus all the back pieces are tapered and the track saw made quick work of this. I had to band saw several pieces and use the TS for the seat slats. Once I routered many roundovers I discovered I needed to sand through the surface a bit. I used cedartone treated lumber and the raw surface is a bit darker than the core. Found a job for my new RAS 115.
My daughter and granddaughter are trying them out (now my wife requested I make a scaled down chair for her):
Ha, then in my spare time I made this quick deck cooler. My wife wanted a rustic look to match a couple planters I recently made:
[attachimg=2]
Hey Mike
Nice work!  The only problem with those chairs is that it looks like I wouldn't want to get back up once in it !  [thumbs up] Where is the napping imogi ?
What did  you use to line the cooler cabinet?
Rob Z said:
Hey Mike
[member=6193]Rob Z[/member]
Ha - they are very comfortable. I actually made a chair and loveset from these plans several years ago but I used cedar. After a few years the fasteners didn't hold up well. Hopefully this wood will do better.
The deck cooler has a cooler inside:
You missed my favorite part - the magnetic cap catcher:
[attachimg=2]
that must be a powerful magnet to grab that bottle cap and pull it sideways 5 inches  [eek]
I think it's in the cap - it's from a Zombie Dust (3 Floyds Brewing).
I knew it! Had to scale one down for my granddaughter:
[attachimg=2]
Nicely done!
Adirondack chairs are maybe the most comfortable chairs used without any cushions for outside use. By the look of yours, it seems that you did a very thorough job!
These chairs are on my to-do list as well. I liked the detail where the back support board are tilted. Because water will easily be trapped here, causing rot when using something lesser than hardwood or teak. At least in our climate, far from yours [blink]
Your granddaughter will probably forever remember you building her a chair, just like the adult ones  [smile]
