I have a TS75 with a MFT3. Using the "5 cut method" I am consistently off by 1/64" inch (wider at the top part of the cut or the end of the cut pushing away). I am using tool improvements bench dogs as my fence so I know I am square to the guide rail. After calling Festool and being told that the factory stops on the guide rail attachments are not always set parallel to each other I set them myself using the bench dogs and the fence that comes with the MFT as a spacer. Problem is I am consistently off by 1/64. I assume it is the ts75 but i don't know what adjustments to make. The owners manual does not address the subject. Any thoughts?
