I made one cabinet out of two. I like the drawers, I want those. I can fit one door next to it. So I cut the cabinet with two doors in half, and then attached one half to the drawer cabinet.
Dowel time. Unfortunately I don't have a fancy Domino for this. I don't do this type of joining often enough to warrant an expensive Domino. I get by with my little dowel jig. All you need is the guide, a drill bit of the proper size, a depth stop for the bit, and some pointy dowel helpers.
Place the guide on the side of the board to drill straight holes.
Insert the pointy helper thingies.
And then press the board on to the joining board. The points are pressed into the board so you can see where you have to drill your counter hole.
Drill the holes, insert the dowels with glue, and push it all together. This method is not very precise, sometimes a hole is a bit off and you have to enlarge it a bit.
I cut off a little piece of the sides so I could place the cabinet closer to the wall. I closed the exposed inside of the melamine board with a bit of iron-on edge banding. You can cut it flush with the orange knife that's especially designed for this.
Well, I made a booboo. The door and drawers overlap. Shouldn't have used a single board in the middle. I hadn't thought of that. Back to the drawing board.
I have a designer friend who would probably call this a feature.
I took it apart again, by gently cutting the dowels with the MultiMaster and a very thin blade. The cuts will never be seen they are on the bottom or hidden by a drawer. Then I added a second board in the middle.
And now it all fits the way I want. Maximum space used, and the oven door can open fully.
I don't have a proper 32 mm counter top for this part, I'll have to use an old 28 mm table top for now. I will replace that later on.
