So I recently picked up a TS 75 and a CT 22 vacuum and it basically blew my tool budget for a while. Not that I regret it, it's just Festool stuff is pricey (but well worth it!). I really wanted to get an MFT/3 table, but I can't afford it at this point in time. I'm just a hobbiest, so getting Festool stuff past the wife is challenging to say the least. With the aforementioned Festool purchase, I've bought about $2k in tools over the past 6 months, and I need to start working on some promised projects for my wife (built in closet, small credenza in kitchen). Before I start cutting wood, I need a workbench. Over the past year, I've been working on the floor or these cheap plastic sawhorses I have.
I need something better. Since I'm a relative newcommer to woodworking, I need a bench that's pretty easy to build. I've done some research; both online and I read most of Chris Schwarz's excellent book (Workbenches: From Design and Theory to Construction).
I liked his "English Bench" design: http://www.popularwoodworking.com/article/Rules_for_Workbenches/
and http://blogs.popularwoodworking.com/editorsblog/CommentView,guid,1e56890f-a012-4bcd-9a7f-5d01168406f5.aspx
However, I'm mostly a power tool guy, so Schwarz's English bench may be overkill for me.
The best I came up with was Josh Finn's design from Fine Woodworking #202: http://www.finewoodworking.com/Proje....aspx?id=31729
I thought it was pretty cool, then a FOG member Russ came up with a modified "MFT-style" design: http://festoolownersgroup.com/index.php?topic=7067.0
Very nice. However, the one thing is I will be cutting a good amount of 16" (or more) wide pieces of wood for shelves and cabinets, and I'll need something that mimics the guide rail and protractor thing of the MFT/3.
Is there a way to incorporate that part of the MFT/3 into either Chris Schwarz's "English Bench" or Josh Finn's (modified by Russ's) design? Or will I just have to use a carpenter's square to lay out my cuts and it's not that big of a deal?
Anyone else have any suggestions for a home-built MFT/3 table?
Thanks,
Greg
Thanks,
Greg
