Angle adapter for d27 hose.
semenza
Festool Moderator
Festool Moderator
Fingerlakes Region NYS
   I am going to work on making one of these for myself, but here is the idea .   I would like an angled adapter to go between the d27 hose and the sander connections.  Mainly for use on the LS130. This would allow the hose to be moved to the side of many pieces  being worked on. So that it would not be dragging back and forth in line with the sander movement, over the end of long pieces being sanded.  Even with the hose coming from above such as on the boom arm I find that it is often in the way.  It would be better in many situations to have it offset.
srs
I have an LS130, and I know exactly what you mean.
One more vote for a good idea.
Ned
Great idea.
I think festool uses such an angled adaptor to connect hose to the vacuum port on the side of the small belt sander, which is not available in NA.
Seth, that's a great idea!  I would certainly use such an adapter if I had one.
Please show us what you have made and let us know how it works.
Another great application would be my Fein Supercut with the dust extraction shroud installed for cutting (not sanding). In its standard configuration the vac hose extends straight up from the machine, perpendicular to the body, it would be nice if the hose was parallel to the body. Would a D27 hose fit into the Angle Adapter for the CT Mini or CT Midi? Item #456806
http://www.festoolusa.com/ProductDetails.aspx?ProdID=456806&ID=6
Lookin' for a prototype?
I got your prototype right here:
[attachimg=1] [attachimg=2]
The dust deflector for the ATF55.
Ned
Ned,
   I was thinking of that myself but my deflector went with the ATF when I sold it, of course.    Does that stay in well enough?
    I also wonder if the  above mentioned belt sander one wood work?   Anyone outside NA want to try it?
    I am also thinking that a 45 degree might be better than a 90.
good one Ned!!................ I actually had that in my hand the other day looking at it over in Culver City.
does it hold well when tugged??
This morning I tried the ATF55 dust deflector on my ETS 150/3.
The deflector is a good fit on the ETS150/3, as it is on the LS130.  It also fits on the oval dust port of my (old model) Rotex 150.  The deflector does not rotate.  Limited rotation might be a useful feature in the real right-angle adapter.
I don't know  if the deflector has anti-static properties or not--if it does, it's just a lucky coincidence, because the engineers didn't expect it to be attached to a hose.
The dust collection seemed to remain effective through the right angle bend, but a 45- or 60-degree bend might be just as useful and create less restriction.
The D27 hose is a friction fit in the deflector.  There's no ridge inside the deflector to create a mechanical hold.  The hose will pop out, and it does so often enough that it's clear this isn't the final answer to Seth's wish.  It might work well enough in certain positions to be useful.  It is worth trying.  Perhaps some duct tape would improve it.
Ned
