Birdhunter
- Jun 16, 2012
I'm building a couple of jewelry boxes and ran into a strange problem. The side pieces are two ply. The outside ply is Cocobola and the inside is Spanish cedar. The total width is 3/4". I cut a 45 degree miter on one side piece with the saw blade tilted to 45 degrees. I checked the cut and found that the cut was not square. I measured the cut with a digital angle gauge and it was off about 7/10 of a degree. This doesn't sound big, but it would leave a gap when the sides were glued together. I then cut a scrap piece of wood and got a perfect 90 degree cut. I did another cut using a jig with the blade at 90 degrees and, again, got an angled miter. I then thought the box sides might not be straight. I lined them up against a Starrett rule and they appear to be straight and parallel. The saw is a SawStop Industrial. The bad cuts only occur when cutting the box sides. I've done numerous test cuts on scrap and they all turn out perfect.
I'm at a loss to explain this anomaly.
