Angled walls inset kitchen install
Jonhilgen
Did this job around a year ago, but never had the chance to get finished pictures of it until yesterday.  This is on one of those jobs that it believe could not be done without a TS55.  I was able to cut the angles on site, with little or no touch up needed once the cabinets were joined together.
All in all one of the most technically difficult (and highly stressful) installs I've ever done.
After I had a panic attack, I had to come up with a plan.  As Otter said in Animal House: "No, in this case, I think we have to go all out. I think that this situation absolutely requires a really futile and stupid gesture be done on somebody's part."
Initial layout was easy, just started on the range/hood wall so I could get some fixed points in order to layout the faceframes so I could start mitering the bad boys.  Once I set (plumbed/leveled) a cabinet, I would transcribe the face of the cabinet down onto the floor, then I would set the next cabinet where it was supposed to go and transcribe that line.  Intersect the points, bam! Now I know where on the face frame to cut, and at roughly what angle to cut it.
[attachthumb=#1]
No need to cut miters on both cabinets on an inside miter...the faceframes were then screwed together from behind.
[attachthumb=#2]
Tight as a tick using the 55.
Lather, rinse, repeat.
[attachthumb=#3]
Now on to the outside miters.  Same process of figuring miters.  Better to err on over-cutting the angle so the points touch at the front of the miter instead of the backs.
More to come when I can find the time.
Outside miter done.
[attachthumb=#1]
Once I set it in place, I glued and screwed some blocking in at the back.  It's not that pretty, and some domino purists may wrinkle their noses, but it works.
[attachthumb=#2]
As I stated earlier, it's best to over cut the miter so the points touch.  Less work trying to fill the entire length of a miter when done this way.
Once base cabinets are set, I installed white melamine on the base cabinets so I could layout the wall cabinets.
[attachthumb=#1]
[attachthumb=#2]
Then I built a support for the wall cabinets to make it easier only back to install.
[attachthumb=#3]
Cutting extended stile with the ts.  I cut a support so the rail wouldn't sag in the middle of the cabinet.
[attachthumb=#4]
Wall cabinets done...
[attachthumb=#1]
[attachthumb=#2]
[attachthumb=#3]
...and since I don't have much time, I'll skip to the final pics
Yes, well done. I'm also a cabinet installer and it's wonderful to see really good work - both during and the result.
I hope your designer troubles are improving.
Thanks Galwaydude, thanks Ron.
Improving? We'll see.  I've spent more time the past week bidding on my own projects lately, I'll be too busy installing my own projects.  Amazing what happens when you free up some time and get off the tools for a bit.
Jon
Found some more pics
Tom Bellemare said:
I love the crisp edges, Jon...
'Totally impressed,
Thanks Tom.  I really don't know how I would have been able to cut these miters so tight without a TS.  That tool really is a game changer.
Jon
Jon
Same here The TS55 has been my workhorse on jobs like that!
Hi Jon
I know how much work and stress an instal like this can be...but let me just say that is a really nice job right there.
Everything looks tight, even and in harmony with the style.
Nicely done Jon.
Best...
Scott
Nice job! That's quite a unique design that you're working with. Did the designer spec it and you just build, or did you have to design it too?
