- Jan 22, 2007
Well Mark, there's a pretty good chance we can replace the poor Powermatic Infrared remote with a Maxsys RF system. For the benefit of others reading this, you previously told me that your PM1300 dust collector has a built-in remote system, but it only works at a 5-foot distance from the dust collector. Not very useful.
The black T-shaped box in the back circuit board is the relay we need to activate. Given the simplicity of that rear circuit board, I'd say there was a pretty good chance that the brown wire from the IR (front) circuit board will trigger that relay. There is also plenty of room inside that enclosure to install a Maxsys module, and have it completely hidden away.
The first thing to do is confirm my suspicion that the brown wire controls the relay. One way to do that is to put a volt meter between Black-and-brown and then later between red-and-brown, while you turn the dust collector on and off. Oh, and get me a black-to-red voltage too.
If you don't have a voltmeter, you could take out the rear circuit board and photograph the back of it so I can trace the wires. (Make sure you unplug the dust collector first!!!!)
Ideally, we could hook up Maxsys in such a way that it won't disable your front controls, including the run-timer. But I can't be positive of that yet.
