- Oct 16, 2015
Some of you guys are way more knowledgeable about this stuff than I am, which brings up the question.
Is there some kind of end fitting that I can put onto the extractor-end of a 27mm tool hose that would be a direct plug-in to the tool-end of my 36mm hose?
What I am looking to do is have a short section of hose "permanently" attached to each of the routers in my dual router table configuration. Then have the extractor ends mounted into some kind of manifold, where I could just plug the 36mm hose into whichever one I wanted to use at the time.
Most of the time, I just plug the 36mm hose into the fitting on the back of the fence, but occasionally it is not a through-cut, thus the chips come out the bottom.
