Another small walnut WIP
rvieceli
Carbondale Illinois
A small piece of walnut making its way through the shop. This will end as a horizontal form table lamp on a textured steel base. Here’s some progress shots.
Problem child but wonderful grain and good color.
Some repair progress
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
That last one fixed a small split on the end
Ron
I see a rogue circular patch  [blink] what happened there?  [scared]
Great work as always Ron.
rvieceli said:
This vac is for the drill press. Not sure but it might be time to empty it.
Did it fill the hose? I have had that happen to my CT26. It was still sucking, but couldn't take in any more chips. It's a bit unnerving the first time, and not the easiest thing to unclog
It’s a short hose because it’s stuck under the drill press. But it only had about a cup in the hose.
It wasn’t sucking right and I thought it was clogged. Pulled the hose off. And noticed it
Ron
Today I am sanding a bunch of stuff. Realized  I need to have finish on stuff by Tuesday in order gor it to cure in time for a show.  [eek]
Ron
In other news, I figured out how to get a wiring hole all the way through a 4.5 foot piece of hardwood end grain.  It is not particularly a fun experience.  [scared]
More importantly, I also figured out how to fix it when it doesn’t go as planned.  [big grin]
Ron
[member=58857]Crazyraceguy[/member] as promised here’s a couple of pics of the finished lamp.
Ron
[attachimg=2]
[attachimg=3]
[member=3192]rvieceli[/member] That looks great, as always. You've got a lot going on there, more round patches, partly smooth and partly torch-cut areas on the base metal, and some fantastic figure on the Walnut.
Apparently, I have missed it, if you have explained it somewhere...do you sell these projects? If so, how? Local craft shows, Etsy, personal website?
Thanks. I do a few art fairs during the year. I also have a website but stuff is expensive to ship.
Ron
Here’s another with curly spalted maple.
[attachimg=1][attachimg=2][attachimg=3]
