Any plans for wider dominos?
Nick2cd
Regarding the 500....it has the capability to cut "exact size", +6 and +10mm mortises.  I would love to see Festool offer dominos that would fit these wider mortises.  are there any plans for this to happen?
Hi Nick,
Welcome to the FOG!  [smile]
I don't think it is likely, but you never know.  You can make your own to fit though.
Wouldn't it be cool if Festool brought out a mini thicknesser that could also make exact domino profiles. They could call it ... wait for it ... the DOMINATOR  [big grin]
Funny I was thinking of that term in relation to a different Domino concept yesterday.  [smile]
I like your idea.
If it was built into a Systainer that had drop shoots in the bottom, it could refill the tenon Systainer while latched on top  ::)  [big grin]
I am going to do a thread later on making a set of large oak gates using the Domino XL and shop made oak tenons but I will put a few pics up to show how I make them. It works for me.
I plane up lengths of oak 1m long to the dimensions of the domino width required, in this case 70mm and with the domino cutter 14mm I thickness the domino tenon to 13.5m.
Then on the router table use an ovolo bit to round over the edges. This puts a slight groove on either shoulder.
Then using a V groove cutter in the router table I put a number of V grooves the full length (how many depends on the width of the tenon) to allow glue/air to flow.
Hope these pics help
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
Mac oops  [embarassed] guy
I wonder what it would cost to have a cutter made which could put on the correct radius with the small grooves?
would be easier if you had a spindle moulder
Festoolfootstool said:
Mac
Mac!! [eek] [eek]
;D ;D i have a toothed cutter for glue joints on the spindle moulder but I would be a bit cautious about putting small sections next to that big cutter head going at 8,000 rpm!!
The router table option is safest to me, the grooves are a bit bigger than a standard domino.
With the XL being such an amazing machine you can make any size tenons up and groove them as many times as you want.
New territory at the moment but perhaps some more ideas will come from this discussion.
woodguy7 said:
Guy, like the stealth gloat showing off the router table  [tongue]
That was for Windmill John's benefit, you know he can resist anything but temptation!!! [drooling] [drooling]
Mmm, I have a sense of "Incoming flak" [scared] [scared]
I am on the edge of my seat waiting for Guy`s up coming oak gates.
[popcorn] [popcorn] [popcorn] [popcorn]
John
We wont discuss temptation OK?
Here is my method of manufacture. makes no sense to plow, the more it is oak.
Just curious, why the need to groove home-made dominoes? I know it's to help glue squeeze-out, but does anyone groove regular tenons?
Seems unnecessary to me.
(Now I'll go and put my flak jacket on.)
Good point Richard.  For me when I make a mortise & tennon joint it has just enough slack to allow the tennon to push through with glue applied without leaving all the glue at the start of the mortise.
I think with Domino's they are so tight they have to have the grooves or the joint would be starved of glue.
Just my opinion & am also ready for the onslaught  ;D
No flak.  I believe that the grooves are there to allow the domino to push all the way down into the mortise.  Like a relief valve.  It does help spread glue upwards thru the insertion action.
spike must be a member of the hand with a slight interference fit - this rule.
I catch just a tightness and not consider it necessary to make the groove.
is my opinion.
