My rule of thumb has always been that if you can push fit tenon & mortice joints together by hand then there will be enough "wiggle room" to allow air to escape and for the glue to form a good thorough bond.
With the domino cutter being as precise and accurate as it is then the joint can be so tight that if you try and put the domino in without grooves then the air/glue cannot rise and it wont seat properly. Trying to get hand cut joints this tight is virtually impossible.
So with shop made Domino's I make them 0.5mm thinner and groove them. Some may disagree and will have other methods.
Its a fine call, you need to have a good firm fit but if you over do it then the joint will be as slack as a wizards sleeve and liable to failure especially with outdoor joinery subjected to all the seasonal changes and the associated stresses.
Like I said before this is early days and experimentation is on going and others may have better ideas.
