Programmergeek
- May 2, 2007
Ok I am a bit upset I screwed up a big piece of wood with the LR 32-sys. I was making holes up a 7' piece and because my guide was the 42" guide I could only clamp one end, it wouldn't reach end to end and I do not have a clamp deep enough to get to the other end on the wood, I don't even think one is made I tried to even make something for my MFT but it would only crush the aluminum rail. Well the unclamped side moved despite my best efforts to watch it and be genital. I was going to do the bottom half and then the top half. So I went to my dealer the long rail is $$$ but probably would of got it but it was out of stock anyhow, I already have so many rails also why don't they just put these holes in all the rails. So I wanted to get another short rail to save cash and move forward on this project I need it done this week and found out you can't clamp them together.
The hole on the end is not 1/2 the distance, it is less so if you clamp 2 together the spacing would be screwed up. I could try to leave a gap but Then you have the issue of play or having a curve if they are not both 90 deg. Why would festool do this other than to only sell the long rail. What if you are doing a project longer than the long rail is this system useless? Has anyone found a workaround for this? The only other thing I can think of is making a jig to set the guide in holes that are already drilled but the holes on the guide are oval which complicates things. For the price of this I can not believe I am having so much trouble drilling a couple holes.
Also I just noticed the long guide is less than 8' long. So are you totally screwed if you need longer than that. Why would they make a longer guide to fit standard lengths of wood you also loose a couple of inches if you use there spacer on the end.
